OnQ ALC setup question
Hi All,
I am setting up a test board to gain knowledge on ALC OnQ products.
Does anyone know whether or not an ALC scene switch switch can be used to control an OnQ relay? I would expect so but when I try to set a scene switch to dim a light and turn on a relay the relay does not respond. The dimmer does fo to the level set in the scene but the relay does not turn on.
Hi All,
Nevermind....helps if you terminate the signal cables on the ALC hub. The scene switch now controls the off/on functions of the relay just fine.
