I want to control a group of M1G input zones (on an M1XIN) with a device that has what it calls "open collector outputs" (aka, O.C.O.). The device manual says the following about connecting external devices to the O.C.O.'s...
The device/board has a terminal block with sixteen pairs of screw terminals, and a 12Vdc +/- terminal block.
Can I use the device by itself to open/close the M1G zones, or do I need to use a relay (for each zone) between the device and the zones in order to provide dry contacts for the M1G zones? If I don't need to use relays, how does this thing get wired up assuming I want the zone to be a normally open zone? The part I don't understand is how to implement the "ground switching" requirement of the O.C.O. device.
Ira
Open Collector outputs are ideal for adding external relays, small lights, LEDs, and other small loads under 150ma at 12VDC. OC outputs work by connecting an external device to ground. For instance, to connect an external relay to an open collector output, you will connect one of the two power leads directly to the OC output. The other relay power lead should be connected to a power supply. The ground of the power supply should be shared with the Ground leads on the OC output.
Ira
