After searching a bit, I found an old reply that says connecting an output (output 7-16 anyway) directly to the 912B relays is potentially not reliable.
The replay said: "Strange as it may seem, I don't think the 912 relays are recommended for direct use with the M1 series. The 912 series require a 30mA trigger for the coil. According to some chats with David, he said this could drop
the voltage too close to the minimum 9VDC pull in voltage and may not be reliable. He recommended the 924
sensitive relays, which only need 1.2 mA to for the coil. The M1RB appears to have the same (or similar)
transistor trigger as the 924 sensitive relay. The 924 relays are about $9 each, which makes the M1RB a
better value."
and the link to the thread from 2005:
http://www.cocoontech.com/index.php?showtopic=2936
(I assume the David mentioned is Spanky, so there's no better source than that)
Wish I had known this before buying the 912B six pack. I guess there aren't any SPDT ELK relays that are recommended for connecting directly to M1G outputs.
Spanky: do you guys sell a retrofit kit (something like the 924 relay board, minus the relays) that sits between on output (Out7-16) and a 912B relay? (Or is it possible you could sell such a thing?) Sign me up for 6 kits if you do ;o)
