Desert_AIP
I have the ELK-930 dorobell detector.
I'm trying to get it to trip an HAI zone.
If I wire the Open Collector output of the 930 directly to the HAI zone, and place a 1K EOL resistor acros the zone, it properly triggers the zone, so I know the 930 is operating correctly.
The problem is the Omni has a fixed 300ms response time, so unless someone holds down the button a bit the zone does not trip reliably.
So I tried wiring the OC output from the 930 through a negative triggered time delay relay to extend the pulse, with the relay wired to the Omni.
I have used this same relay and technique to extend the 50ms pulse of the Hydreon rain sensor and an IR door threshold lighting trigger, and they work perfectly.
But one has a relay output and the other has a positive voltage output, not OC.
I have the zone wired across the NO terminals of the relay with a 1k EOL bridging them.
With 12VDC power applied to the relay, if I use a jumper to short the "-" side to the negative input terminal, the relay operates as expected.
I have the "-" side of power wired to the "negative" terminal of the 930.
I have the "ouput" side of the 930 wired to the negative input of the relay.
After reading several threads here I also added a diode on the "-" side of the relay power.
When I press the doorbell button the doorbell rings, so the OC output should be bridged, but the relay does not operate.
Even if I hold the button down like I did when the OC output was directly wired to the Omni, it does not operate.
If I place a jumper across the "negative" and "output" terminals of the 930, the relay operates as expected.
I am stumped.
If I understand simple transitors and OC outputs correctly, negative power should flow from the negative terminal to the collector.
So I believe I have it wired correctly.
Do I need some kind of load resistor on the OC output to produce a current?
I am stumped.
