PC Access Network Options
Lake
I upgraded from a Omni LT to a Omni IIe and is connected it to my network through the ethernet port. I am trying to use PC Access to connect to it but I cannot configure networking because Options -> Network is greyed out. The other items under Options, such as General, Modem and Serial are selectable but Network is not. I changed the Omni's IP address to 192.168.10.101 to fit into my network and can ping it. I have the latest version of PC Access, 3.6.0.586. Any ideas?
Are you opening your old LT account file then trying to configure the network settings? If so this will not work. PC Access knows that the LT does not have network capability so network settings are disabled.
Create a new Omni IIe account file and you will be able to configure the network settings.
You need to enter the two piece encryption key from the new controller.
Under Options-Network.
You have to get the key from a console on the new controller.
From a Console:
9 - Setup
6 - Misc
Down arrow
Kepp scrolling down. You'll see the IP address, port number and parts 1 and 2 of the key.
Write these down and enter them in PC Access.
Worked perfectly. Thank you very much.
