IVB
Generally speaking, i'm underimpressed with the tap. I separated the bridge from my router by 6 feet, switched channels, still not reliable. Not enough data to give you solid #s so guessing but:
1) Pressing a button turns off more than the associated lights 35% of the time. It feels like its triggering buttons on several taps (4 taps, button 3 & 4 each turn off local lights, but pressing button 4 in one location also triggers the button 4 off command in a different location).
2) 20% of the time it'll take 1 button press to turn a light on. 60% of the time it takes 3-4 times. 20% of the time it takes 6.
Hue is definitely being relegated to my 3 table lamps, in my house anything less than 95% = everyone says dad is screwing up. I have 10 Hue or Link bulbs in 4 ceiling locations on switches that don't currently have enough space for a single gang, but I'm calling an electrician out to run new wire to 6 other locations, I'm 99% sure I open up the walls in 3 of the locations and put in a single gang. The 4th location is sandwiched between 2 studs, but i'll bet I could cut 1/8" on either side and rubber mallet it in. Then I can go to zWave (or RadioRA or whatever) for those.
