jrfuda
Guys,
I'm putting together a "nanny cam" system based on IP cameras. I know it's not the best way to go about this, but I already have a good bit of the hardware. We're hiring an au pair to help my wife with the kids while I'm deployed ( http://www.cocoontech.com/index.php?showtopic=4852 ) and the wife would like to be able to check in on the au pair remotely, allow me to see the family when I'm near an internet connection, and allow us to have recorded evidence "just in case."
I already have 6 d-link DCS-900 IP cameras, which I've used successfully in the past (though they have no low-light capability at all, and IR doesn't help). The full-version of the IPView Software (which does not come with the DCS-900, but can be downloaded from dlink) is rather powerful and supports up to 16 cameras, ftp and email. The individual cameras have a webserver for direct access.
To simplify installation, I'd like to be able to run a single cable to the location of each camera. The cameras currently require a network connection and 5VDC. A PoIP/PoE dongle that can combine these onto a single piece of CAT5 is ideal.
I've looked around and found complete solutions (both ends, with AC adapter) for $80-$100, which is more than I want to spend.
I've also found some individual devices (would need two per cam) for $15-$20, but these will require a little hacking (I'd have to adapt each camera's power supply to the DC in/out on one dongle, and then adapt the DC in/out on the dongle on the camera-side to match the DC input on the camera).
Has anyone out there used any PoIP devices before? Any advice? I'll need hardware for 6 cameras.
My idea for the setup is to have a dedicated PC just for this function. I've ordered one of Geek.com's $219 P4 systems to take on this function. It will run WinXP Pro, IPView and WebCamXP... and maybe girder.
IPView will be ran to fill the entire screen, which essentially makes it look like a normal securty camera matrix screen. I'll use WebCamXP to stream this screen (essentially the desktop) to the web, which will allow the entire "matrix" of cameras to be viewed, and each camera can also be viewed directly for their built-in browser. I'll create commands in girder to allow the current view in IPView to be controlled remotely, and let IPView manage FTPing and/or emailing motion detected, as well as recording it locally. Alternatively, I can use one of the newer versions of WebCamXP exclusively (leaving IPView out of the picture) since it can communicate directly with the IP Cameras. However, I am leaning towards using IPView becuse it will enable me to output its current view over composit video and into my modulated video system, allowing the wife to view and control (via IR) the current view in IPView.
Anyway, I'm mostly looking for advice about PoIP dongles...
