Greetings all,
I'm having a hard time wiring a pull up resistor as per the Webcontrol manual where it is mentioned to wire a 2.2k pull up resistor to fix the issue where you get multiple emails when a button is pushed.
I have two button push type inputs on my board, and when the inputs get a signal they send multiple emails, normaly two emails per push, but sometime more.
On IP1 i have two wireles coming from a push button that one of the wires is hooked to IP1 and the other to GRD on the input module on the cai board.
The other is as well a 2 wire coming from a keypad and one wire is going to IP2 and the other to the 5v on the input module of the cai board.
I'm getting emails but too many and as this is mentioned in the manual that there is a solution I would like to fix this.
IF someone could do a small drawing that would be greatly appreciate it, as I can't figure it out by the description.
Thank you very much.
