wkearney99 said:And in what situations would you install a dimmer and not want to use it as such? If you're thinking that might be a way to avoid issues with LEDs don't be to quick to jump to that conclusion. I've run into a few LEDs that just did not want to work properly AT ALL off of a 6D, no matter what dim levels or defaults I used. I didn't try the switch mode, but I wouldn't expect that to be any different than the way the default off/full settings are handled in a dimmer anyway.
I have a few places with non dimmable CFLs with a UPB switch set to dimmer disabled. If I can't change the switch mode I'll probably end up replacing the bulbs. These are in areas where I don't need the ability to dim the bulb so it seems like a waste. I could buy the 8ANS switch, but for future flexibility I'd rather have a dimmer.
The 6D dimmer has no neutral so it has a 50 watt minimum. The switch runs a small amount of current through the bulb to power itself. If you look at the 10ND or 6NA the minimum wattage is 10 or 5.
