philgrocks
Hi Everyone,
I just purchased 12 RC2000 thermostats to replace my old, but working well rc-122 thermostats.
After installing 7 with no problems. I got to the 8th and after installing I found the menu for thermostat address setting is missing. I thought I must be loosing my mind. So I went to one of the other thermostats that I had already installed and it had the menu. I also noticed that on the thermostat with the missing address setup, it was also missing humidity.
I did a factory reset on the thermostat and nothing changed.
I then went thru the rest of the thermostats and found of the last 5 only one had the ability to set thermostat address and humidity.
I then went thru the house and I found two of the thermostats that I successfully set the address now are missing that menu choice (as well as humidity).
I already sent HAI / Levition a message, but they don't reply on weekends.
Also worth mentioning... The thermostats are all from the same batch. The serial numbers are in sequence. The problematic thermostats are mixed in the batch.
Thanks for any help.
Phil
Phil
