Hi @pete_c
Thank you for assisting me with this, I need to clarify a few steps so I'm on the same page......
When you say, "
1 - backup current upgraded firmware set up via PCA",
I don't follow? My system is upgraded using physical EPROM, and PCA and
is set to 4.0D. I don't have Flash Capability like newer controllers. Or is there a step I'm unaware of you are recommending?
I only
downgraded once (swapping proms), and since I had multiple unexpected issues I removed the 3.12D PROM and
reinstalled 4.0D EPROM.
- After reinstalling 4.0D EPROM, I RESET EEAROM from Console.
- Then I ran into changes to IP address (as you noted above) issue, because it was Hard Coded as a subnet address ending in 211, older FW. I was unaware IP address was now flexible, and had a default address.
- had to set my Installer Code in two locations, before PCA would connect TCP/IP or Serial (This was new since I hadn't done this since 2002).
- I reprogrammed from PCA both TCP and Serial (unaware of the Ethernet flooding issue you detailed, and IPTV was streaming on LAN).
Just to Clarify, when you say "2 - cold restart the panel", do you mean "
RESET EEPROM" from console? My guess is the configuration is stored in EEPROM because removing power only clears RAM not programs.
I don't trust configuration loaded into EEAPROM initially because I didn't know about the
Ethernet Flooding issue, so successive reprogramming through
Serial port or
Ethernet has not resolved controller misbehavior (and multiple System Resets), hence I think I should start over
if that is what you suggested in No. 2.
I noticed after removing Ethernet connection (last night), I'm still flooded with "
System Resets" so I imagine what is memory (not just RAM) is corrupt, hence I think you want me to
erase FLASH Memory.
I deeply appreciate the help, I regret testing older firmware because it has opened a can of worms, when the original ALC issue was caused by Ethernet flooding, which I was unaware until yesterday.
-Bob
