sanders2222
I am replacing a 30 year old alarm system with the ELK M1 Gold and a newbie to this technology. My panel is located in a central closet location and I plan to relocate my PLM next to the ELK panel. The ELK panel will be mounted to the wallboard where the existing system is and use the wires coming out of the wall, plus install some new wires and cat5 cables as needed. My ISY-99i is located in another centrally located closet and I have purchased the ELK module for the ISY.
- I have monitored the status of my garage door with an Insteon I/O Linc 2450 through an ISY-99IR. But I understand the ELK can do this to and may be a better security solution. So my question is should I eliminate the I/O Linc and run a hard wire connection to my ELK?
- I also have a sump pump located just below my ELK panel location. Can I use the ELK to monitor a water overflow switch in the event my sump pump goes out? This would eliminate the need for another I/O Linc and perhaps provide better security.
- How many electrical outlets should I plan to install next to the ELK panel? Any suggestions are welcomed and pictures of panel installs would be helpful.
- I understand the ELK will 'talk' to a Russound CAA66 whole home distribution system. Has anyone successfully set this connection up?
