TheDeepRough
First of all, this board is pretty amazing, love the amount of information I have found here already!
We recently purchased a new home, that was outfit with a pretty dated 'Dictograph' security system. I have brought along, from our previous home, some Insteon capable devices (dimmers/etc). So, I would like to start down the path of some simple HA and at the same time, reviving the existing security system.
I have been looking at the Elk M1 a fair amount, and it looks like a system I can grow into, integrate existing Insteon devices as well as add additional ones down the road.
Here is my question though. The 'Dictograph' security system in place today has the following:
- Approximately 20 windows fit with magnetic contact sensors, all wires routed to the existing security planel
- 6 'plunger' sensors mounted in doors, wired to the existing security panel
- An internal siren, an exterior alarm bell
- A number of small indicator lamps around the house (presumably when the system was armed, they would be lit?)
- A couple of physical key switch panels, two indoors, one outside, that were used to arm/disarm the system
I am not so interested in the physical keys, or even the indicator lamps. But, how can I go about determining if I can re-use these magnetic contact sensors with the Elk M1? Are all sensors pretty much the same? What about the plunger sensors? Assuming it does work, does anyone have any advice on how to quickly identify which leads at the current panel go to which sensors? Or, is it just a lot of walking back and forth?
Has anyone had experience doing something similar in the past?
Thanks!
Thanks!
