Over the last couple of years, I've replaced most of the unmananaged switches in my home with managed switches. I've also added enough non-computer devices to my home LAN to make me start thinking about incorporating VLANs. I'm curious as to how other people are using VLAN's in a residential environment.
My internet connection is via a DSL modem. It connects to a router that doesn't have VLAN capability. The router has a managed switch connected to it, along with a few other devices (two printers, two NAS appliances, a timeserver appliance, a wireless router in access point mode, and a PC that is in the same room). The managed switch connected to the router (also in the same room) has a "general purpose" PC, my HA PC (running CQC, weatherlink, brultech), and a UPS attached to it, as well as several other "point of use" managed switches and a couple of "point of use" unmanaged switches.
The point-of-use switches vary as to the types of devices connected. For example:
1. A managed switch in my den with all of my primary home theater devices attached to it...DVR's, WDTV, AVR, TV, etc.
2. A managed switch in my master bedroom with some secondary AV devices...a DVR, TV, WDTV.
3. A managed switch in my office with computer-related devices (several PC's, a printer, a NAS box, two local UPSs), a DVR, and a TV.
4. A unmanaged switch (industrial high temp rated) located in my attic that has most of my other HA stuff running thru it.
I also have a unmanaged switch in my shop that connects to the unmanaged swith in my attic. It has mostly HA stuff plugged in, but I also use a computer in my shop occasionally that needs connection to my other "computer stuff".
I'm also starting to play around with a IP security camera. The one I have is wireless (for convenience during the learning stage) but I expect that I will end up with several wired cameras.
I understand that VLANs allow me to segregate different types of data, e.g., Audio/Video stuff on one, Home Automation stuff on another, and PC stuff on another. Where it gets confusing to me is when I need to cross boundaries. for example, I want to control my AV and HA stuff from an iPad via a wireless LAN connection, but the iPad also needs internet access, and access to the NAS boxes and printers. My AV and HA stuff need internet access. I may want to get to the HA stuff (e.g., Elk RP2) from my "regular" computers. I may want to view the security cameras from my TVs. I know you can define VLAN's such that some devices can access a different VLAN, but if most devices can cross boundaries, are there really any benefits to VLANs?
In a VLAN environment, does endpoint device connected to a unmanaged switch (which is then connected to a VLAN enabled port on a managed switch) become a part of the same VLAN? For example, am I forced to have every device connected to my unmanaged switch in the attic (including the devices connected to the unmanaged switch in my shop which is connected to the attic switch) live on the same VLAN?
Am I gaining any funtionality by having some "point of use" managed switches, all connected to a central managed switch? If the answer is yes, what did I gain?
Seems like with the price of managed switches getting pretty reasonable (about $10/port), and more devices getting connected to the home LAN, VLANs are something that need to be understood/considered.
So how about some recommendations on how I set up the VLANs, assuming it's worth doing.
Ira
Ira
