frozenteeth
I currently have an EK M1 with a simple setup. A keypad, bus expander, z-wave module and an Ethernet module. The only sensors I currently have is a water sensor on zone 8 that works great. This is a new install so it's my DIY project. I have two motion sensors that I had laying around for years (in case I decided to install a security system). I tested both of them with a two foot long 4 wire cable (22 gauge) and they both work perfect in a normally closed setup. I ran my cable (35 foot run) to the location of the first sensor and tested it and it doesn't work. I tried the other sensor and it didn't work! So i tested them again with the two foot cable and they work perfectly. So I decided to try it on a long run of the cable that I have (approx 50 feet) and it doesn't work.
Am I doing something completely stupid? Which is possible
Is there a limit on the distance? I tested the voltage and ohm impedance and everything seems normal.
Any thoughts?
thanks
Any thoughts?
thanks
