I received one sporadic Keypad Error and started researching RS-485 bus errors. I searched the CT forums and read the Elk documentation to no end about RS-485 termination. I have an ElkM1G, M1DBH, and M1RF2G. Basically, I found out that RS-485 bus resistance was 179ohms without a black jumper placed on JP3 on control board. This value is out of tolerance. In small print on page 12 of installation, it say's:
RJ45 Terminating Plug Insert in first unused jack and terminate the control at JP3. DO NO TERMINATE AT ANY OF THE DEVICES.
Yes there was user error, but seeing how the M1DBH helps with home-run wiring, the instructions should be much clearer in my opinion - especially since the majority of installations I have seen on this forum use M1DBH. IMHO, the documentation should be more detailed as the 178ohm configuration appeared to be working correctly.
Example Instructions:
1) Make sure there are no J2/J3 jumpers on any keypad or expander board.
2) Make sure JP3 has a jumper
3) Check the RS-485 voltage
4) Check the RS-485 resistance without power enabled
5) Monitor the system diagnostics (using keypad) for small amount of time to ensure RS-485 bus is operating correctly.
With JP3 jumped, the resistance is 68ohms.
68ohms
M1DBH Socket 1 – Keypad
M1DBH Socket 2 – M1RF2G
M1DBH Socket3 – Terminating Plug
Black jumper
on JP3 at control board
179ohms
<no JP3 jumper which seems to be factory default>
