Room to grow
I plan to RAID, then carve up into 50GB or so for system drive and carve the rest up.. haven't completely decided how... but from what I read, you can get around the 2TB limit in XP if you take 2 or more logical drives and span them in XP (can't be the system drive). ...
you can do that using Dynamic Disks, and you must have XP Pro to use them. However, there is no fail safe for dynamic disks. if you lose 1 disk, you lose them all. i would only recommend that way if the data is easily recreatable.
i would have to look to be certain, but are you sure you can get around the 2TB limit that way? i think youre capped there regardless of how you try to get past it. its certainly worth a double check.
edit: this is probably the best resource currently on the Internet for large storage arrays in home use
http://avsforum.com/avs-vb/showthread.php?...p;highlight=gpt
