Mr Spock
I'd like to confirm the J1 serial port pinout, if anyone here knows it. The jumper is set to RS485. I see that its a 6 conductor connector, but appears pins 1 and 6 are no connects so a 4 pin plug will work.
This is what I'm seeing on my oscilloscope when I send a command to this serial port. Pin numbers are referenced looking at the OPII board, reading left to right.
Pin # Waveform
1 = No Connect
2 = Ground
3 = +5VDC
4 = Ground referenced pulses (RS485A?)
5 = +5V referenced pulses (RS485B?)
6 = No Connect
Thanks.
Pin # Waveform
1 = No Connect
2 = Ground
3 = +5VDC
6 = No Connect
Thanks.
