Hi all...frustration has set in and I cannot figure this out. I am gonna see if someone here can most likely point out the obvious. I just got a 3805 off Ebay and it seems to work just fine. I want to serially connect to CQC but I cannot get it going. Here's what I tried.
1. I first attached it to my Comtrol 8 port PCI card, tried 2 different COMM ports.
2. I went through hyperterminal a (9600,8-N-1, Flow Off) and could not send any commands. I could see hyperterminal receive On/Off, Volume changes when I manually changed the 3805 but I could not send any commands (echo on and off)
3. I did try to connect to CQC to see if it would work anyway...I got Waiting to Connect (When I have it connected to hyperterminal, it changes to Waiting for Comm Resource).
4. I went and tried the PCs serial port through COMM 1 and it would not work either.
5. I have sifted through all the forums and could not find anything to resolve the issue.
6. I found someone using RS232 HEX tool so I tried that. I first used Serial Device monitor and got the HEX commands that correlated with the ASCII commands. So, using HEX I could change the MV. So, I can talk to it but not using ASCII. This was through COMM 1.
I know my COMM 1 works b/c I have used it to connect to my Aprilaire setup to test.
That's where I am stuck. I don't know if I am missing something in the COMM ports properties to allow it to send ASCII and not HEX. Any thoughts?
Unfortunately I will be away until Sunday to try anything but I wanted to get something going for when I get back to try.
This has been crossposted to the CQC Forum as well.
Eric
Eric
