The Picco Z is identical to the AirHog from Target...just $10 cheaper at Target.TonyNo said:I have two heli's from Radio Shack. A Picco Z $(39) and a Blade Runner ($59). The Picco Z fits in my palm and the
Looking from the rear,twist (carefully) the tail rotor clockwise slightly and try sticking a couple of the aluminum weights on the lower portion of the nose. That should give you some forward motion.....jay said:I can trim it so it doesn't spin on it's own lateral axis but I'll darned if I can make it fly where I want to w/o dropping from the sky.
Thanks Gemini.Gemini said:Looking from the rear,twist (carefully) the tail rotor clockwise slightly and try sticking a couple of the aluminum weights on the lower portion of the nose. That should give you some forward motion.....jay said:I can trim it so it doesn't spin on it's own lateral axis but I'll darned if I can make it fly where I want to w/o dropping from the sky.
