As mentioned in a previous post, I have homerun 4-wire to several locations where I plan to locate smoke detectors. Since I cannot now easily run wire between two of the locations I believe I have two options.
Option 1 - use 4-wire smokes and setup 2 separate zones.
Option 2 - use 2-wire smokes and make connections at my home run to setup a single zone.
Recommendations are appreciated. I'm not sure of the pros and cons of 4-wire vs 2-wire smoke detectors vs the tradeoff of 1 vs 2 zones for smoke detection.
Thanks for the help!
