Dell,
You are plain wrong.
CO should not be in a furnace room at levels unfit for human respiration.  In other words, a CO detector should not sound an alarm in a furnace room.  In fact, I just read where commercial building codes are requiring CO detectors in any room with a permanently installed fuel burning device (ie the furnace room)
Trace amounts of CO exist everywhere even without humans.  CO detectors don't detect trace amounts because they would always alarm. . . even on a sailboat in the middle of the ocean.  That would make them quite useless.  CO detectors detect levels of CO that are unfit for human habitation.  If your furnace room has levels unfit for human habitation, well that is bad.
Sorry if I didn't say put a plenum detector in a plenum.  Perhaps not as self-evident as I thought.
Holy smokes.  I just priced one.  I thought they would be like the smokes . . . wow. .. $500.
Lou,
Yep, you're right regarding the trace amounts, but then again, once that furnace or HWH fires...nope, nothing changes in the enviroment. Of course, now you're going to argue that CO stratifies in the air. I also would wager that you didn't look into the levels and time periods prescribed within the standard and detectors for an alarm in addition to what is considered trace, elevated, and hazardous for human respiration.
Prior to soapboxing on what is incorrect or wrong, I'd recommend taking a look at the installation documents and standards. I would direct you to page 3 of SS's 1224T, left hand side of the page for starters that directly contradict your statements....
in the manufacturer's own words.  I'll point out these links for you to review at your leisure.
http://www.systemsensor.com/pdf/SCFL001.pdf  http://www.systemsensor.com/co/pdf/CO-5-things-to-know.pdf.
I forget, what do you do for work with regarding system design, installation and maintenance? I must be missing something in what I deal with on a daily basis? I'd fax or email my trade licenses and NICET certifications and my company's OEM status, maybe have a fire marshal provide you some information also, but honestly, I've got nothing to prove to you
@ NEW/Chris: CO installation criteria is covered in NFPA 720.The installation instructions can't be used as a design criteria, they only provide the enviromental and general information, like smoke detectors. I can't find the hard numbers on the present versions of the CO1224's, however the equivalent (same element and technology)  250-CO list 10'.
@ dennerline, for CO (assuming the extra oxygen molecule is in error) I believe, if you look at the chart on the CO1224's, I'd call the response appropriate to provide a valid alarm and keep nuisance alarms at a minimum, since in the end, we're dealing with a chemical element that can't be electronically compensated for drift like a PE detector. The Nighthawk units are better than nothing, however their sensing element is a different technology than an alarm system CO.
