Solar sensor
pbako
This looks like a common question, but here it goes...
I have the Temp/Humidity/Solar sensor (part HTS3-R1-A), from which I am able to find the serial numbers for the temp and humidity sensors and read them without problems. However I am having no luck in figuring out how to deal with the Solar sensor. I'm using the C API kit directly from Maxim and have compiled their sample apps with which I can read the Temp/Humidity sensors. I have also compiled their utility which scans the 1-Wire network and reports all of the devices it finds, but it the only serial numbers I get back are for the Temp and Humidity sensors. How do I access the Solar sensor?
Since I am doing this all on OpenBSD, I cannot use the Java tools...
Peter
Peter,
I'm looking at the same thing at the moment - just figuring out what to do with my code to make it work.
What I can tell you though is that the Solar sensor is not a separate 1 wire chip. The DS2438 Battery Monitor in the HB H/T/S sensor is used to read the values from the Humidity AND Solar sensors, it's the DS2438 serial number that you're seeing - not the humidity sensor
regards
Dave
Dave is correct that the humidity and solar use the same DS2438 chip. The humidity uses the VAD input and the solar uses the VSENS input.
Eric
