Successfully moved HAI PC Dealer Access to Windows 11 Pro system
genesain
So, I have been in the process of upgrading from my Windows 10 Home system to a new Windows 11 Pro system. I have an old OmniPro II board that does not have BIOS update capability, so I am using just the door sensors and some ALC lights that are programmed. I have been running version 3.17.0.843 (2018, which is not the final free version referenced in the forum) of the PC Dealer Access software. When it has done updates in the past, I have saved the downloaded update files, which provided me the same level of installer, which in theory requires a serial number which I had from original purchase.
So I installed it and got the new hash for encryption requirement. As posted here I did the rename PCA01.CFG to Old several times trying what I thought be my old hash key, but no luck.
My serial number when input shows as invalid - but it seems to actually just ignore that, and it would not take my old password, so I just did the login several times to enable "password" to be the new password, and I was in. ( I have my original version 2.11 CD, but ran into other errors trying to get that to install, and then I would have had to do the update installs anyway .)
Now the issue became the inability to read my CurrentPCA file due to it having a different hash when it was created on the old system.
The solution was right in front of me. I logged into the old system and simply Exported my CurrentPCA file. It creates a file with an exp extension. I copied the file over to my new system, and from my new PC Dealer Access install I simply Imported it and everything worked exactly on my old system. The file is now encrypted with my new hash key from this installation. Bingo !!
My old PC crashed. I have installed latest Dealer PC Access and works fine. I have a backup of all PCA files from my old PC. When I try to use them I get a "not a valid account file" error. I cannot use the export/import fix as mentioned above as i cannot import from a dead PC. Anyone have a fix for this? Rename file???
Thanks!.... Do you mean the PC access version from my old PC? 3.17.0.843 When I check the properties of the PCA file in question there is no version history data displayed?
I installed the final Dealer PC Access and was able to open old files directly (no export/import needed) by replacing both the newly created PCA01.CFG and user.config with copies of the old files. The user.config contains the encryption keys and is in the hidden AppData folder:
Code:
C:\Users\YOUR_NAME\AppData\Local\Home_Automation,_Inc\PCA3D_EN.exe_Url_LOTS_OF_CHARACTERS\3.17.3.861\user.config
