Phoenix1701
Ok thank you Pete. I’ll try to do that this coming weekend. Along with working on the modem and port forwarding, because that was replaced this past July and it may not be setup.
But can you or someone else also tell me where to find out where items are programmed to be on, but not part of the automation program? I just haven’t been able to get in to things to see settings. One item in question, if you look at printout, is output #261, porch receptacle, is always on. I don’t see anything in the automation log concerning it. I can edit name, but that’s about all I’ve found.
Or am I looking at it wrong? There is no automation for every output. Automation is told which ones to control, but all the rest are controlled through PCA as if PCA is a light switch, turning things on and off when needed?
Mike
Mike
