That brings up another issue that may need to be given consideration. If you close a valve on the water line for an extended period of time, you may create a "closed system", meaning that there isn't anything that will handle an increase in water pressure downstream from the valve
Good point. I had not thought about it because we already have an expansion tank -- the city here requires all water services to have a pressure regulator, which acts like a check valve, so an expansion tank is a necessity.
