upstatemike
I was reading the M1 user manual and it wasn't clear to me how you set a thermostat from an Elk keypad. It talks about viewing the temperature (I assume that would be the setpoint?) but not how to change it.
I am also a little unclear on how remote expansion works. On Caddx systems you use a supervised power supply to power remote expansion modules and the devices connected to them. I didn't see a supervised remote power supply for the Elk. I also thought I saw somewhere that you are not supposed to put smoke detectors on remote zone expanders. Is this true?
Also the KP2 is described as being surface mountable over a 1 or 2 gang box... Do you need the box or can you just go flat on the wall and use a piece of wiremold type raceway to get the wire to it?
