Regarding power: I understand appropriate power is very installation specific but I'm wondering if someone could give me some power suggestions so I could allocation appropriate 'space' in my cabinet. Will I need one additional power board and a battery or should I get 2 boards and 2 batteries for expandability/reserve or ... ?
Thanks again!
Any system if wired with the correct relays can provide the power output to sustain multiple sirens. The run time is dependent upon your needs, assuming you're trying to maintain UL standards.
Things that will affect your run time is the actual load(s) your system poses on the battery system. So you will need to design and make the appropriate load calculations to determine what your expected run time will yield.
Bare in mind this assumes a lot of variables about how fresh the batteries are, and the ampacity they can provide as the years go by. Like with any system these critical systems need to be tested on a monthly basis to vet and validate their actual performance.
I can literally count on one hand all the DIY users I know that test their systems on a monthly basis. These are the very same people who say they test their smoke alarms and also change out their batteries. :huh:
With anything such as security, its a lifestyle . . .
If you incorporate and instill those values into your lifestyle it will be second nature. If you make a system too complex, or hard to use in a daily setting.
It will not be used and it will be ignored, this is fact. If you make the appropriate space allowances for the cans in your system and have the proper wiring in place. Wiring multiple batteries in parallel is not a problem (heeding all manufactures charging limits of course)
Keep in mind, no matter what anyone ever tells you about the so called system load test. You will always perform the load test once a month to confirm the system is fully operational and functional. If you live in the cold aszz north as I do, you will perform the exact same test when its -45'C as it is here.
In the extreme temperatures the current loads will at times double, which may not be present during the beautiful 20's weather most people test in. That is the only caveat about installing an exterior siren that needs to be addressed as it could pose an extreme load to exceed the bells current limit.
Some users circumvent this problem by using powered sirens, the benefit is the alarm system during high loads is not presented with the full load during extreme conditions as the BUB (back up battery) acts like a buffer to ensure the initial siren blast is not a load exceeding the bells limit.
Just something to consider should you go down this route. As others have commented before, proper cabling diameter is paramount to ensure voltage drops are not part of the equation.
Teken . . .
