Sacedog
I'm getting ready to order my Elk M1, and wanted to post my setup to have everyone pick apart. Brandon has already took a look at it, but I thought it never hurts to get a second set of eyes looking at it, and it has changed slighly since then.
I plan on using the Elk for security, and to control my lighting and thermostats. In addition, I would like to use it for some other automation in the future, such as tying into the garage door opener. I plan to home-run all contacts and sensors, with the exception of the smokes, which I now know I cannot install myself (local planning dept REQUIRES 120V smokes). I will probably run wires to one of the smokes, and replace that with the GE 350, which will give me reporting back to the Elk; however, I will not be able to identify the smoke that is going off.
The house is 2 storys, and approximately 4,400 sq ft. I have attached drawings, showing the location of all security-related items.
- (3) CO Detectors
- (13) Door Contacts
- (2) Garage Door Contacts
- (9) Surface Mount Contacts (Gates, Wine Room, Gun Safe, Furnace Filters)
- (1) Combustable Gas Detector
- (8) Glass Break Sensors
- (6) Heat/ROR Sensors
- (3) Keypads
- (10) Motions
- (2) Interior Sirens
- (1) Exterior Siren w/ Strobe
- (8) Smoke Detectors (Although I will only be wiring up one now)
- (2) Thermostats
- (12) Water Sensors
- (1) Weigand Reader
- (25) Window Contacts
I plan on purchasing the following items:
- Elk M1GSYS
- Data Bus Hub
- (5) 16 Zone Input Expanders
- Output Expander 8V / 8R
- Ethernet Port
- (3) Serial Expanders (1 for lighting, 2 for thermostats)
- (3) Elk Power Suppplies (P624) (This may be too many now that I do not need to power all of the smokes)
- (4) Power Distribution Modules (PD9) (Should these be a 1-to-1 with the P624?)
If you see any holes in the Elk purchase, please let me know. Also, if you have any suggestions on the security plan for the house, feel free to pick away! :blink:
- (3) CO Detectors
- (3) Keypads
- (10) Motions
- (2) Thermostats
- Elk M1GSYS
- Data Bus Hub
- Ethernet Port
