I'm in the middle of upgrading and expanding our security/safety system. I'm replacing a wired Westec 5000 panel with an Elk M1G (with all of the trimmings). The current system provides fairly good perimeter and interior coverage, but I'm thinking about augmentation.
Aversion to battery maintenance. Also an aversion to opening up walls to run cables. So I'd consider adding wireless window or door contacts where needed, but prefer wired expansion. I have no problems running additional cables in the basement, attic, and accessible walls.
Questions:
Do folks prefer glass break detectors? Window contacts? Both? Motion detectors? All-of-the-above? Obviously door/window contacts have the added benefit of an 'open' alerting. And I might be able to use the motion detectors to provide crude occupancy detection for automation purposes.
Are state-of-the-art glass break detectors reliable? Problems with false positives? Any performance differences between wall and ceiling mount units? Good/Bad brands and models? I have no specific budget and generally prefer high quality products at a 'reasonable' price point.
I have lots of options for wireless door/window contacts. Since I have NO existing wireless infrastructure, I can go down the Elk, GE, or Honeywell paths. Any words of wisdom? Are the battery life specs on the sensor data sheets accurate?
What about the concealed wireless windows/door contacts that are embedded into the frame. Any reliability issues? I see that in some cases the battery is NOT field replaceable and the entire switch assembly must be replaced. Comments? Do they really last 10 years as stated in some data sheets.
Thanks.
Questions:
Thanks.
