I have an M1 temp sensor mounted in my weather station to monitor the heater under the rain collector to avoid freeze up and damage to the collector(it is in a weather protected area).  My wire run is about 150 ft from the ELK.  The first 100ft is Cat5e and runs from the M1G to the opposite end of the house.  The outdoor run uses 5 wire sprinkler system wire and it is buried underground out to the weather station.  Two of the outdoor wires in the 5 wire cable also carry 24vac @1amp to supply the heater power.  The other three wires in the sprinkler wire cable connect to the +12, Gnd., and signal wires from the Cat5e cable for the temp sensor.  I have not been able to get an M1 temp sensor to operate reliably across this connection.  As an alternative, I built up an LM34 circuit and scaled it up 10x to 0-10v using an op amp and while it operates correctly on the 100ft Cat5e run, the output voltage reads over 11v(should be 3.4v at 34 degrees) when installed in the weather station.  I have rung out all 5 wires in the outdoor cable and all check out(no open conductors, and no resistance measurements between wires).  I am currently thinking that the 1amp/24vac signal may be coupling over to the low power wires for the temp sensors.  Does anyone have any other ideas of what might be going on?
