todster said:I didn't clearly explain. I have the 7805. I cut the trace and installed it. I'm powering it with 24Vdc from the PLC I'll be serially talking to. I jumpered from the 5V output of the 7805 to the power to the analog amp. I currently have no plans to use the analog but may in the future. Currently the analog with the 5V applied outputs a static 3.6v with nothing connected to the board and not connected to the WC.
I already scratched it between the cap and the V+ ( where it says GND TP1). I already scratched where indicated when I installed the 7805. From what I can tell the 7805 still feeds 5v to the WC on pin 13. I don't mind feeding the W/C the 5V as long as I know that the common source for both is exactly that, common. Which is why I want to get a 7808 or something along that line to power the WC and the RW breakout board from the 7808.
On the image above, the RED shows the power trace from the +V pin on the analog connector going to the bypass cap, the regulator and the opamp.
The YELLOW is the jumper link across the regulator (if not fitted), joining that to the WC board +5V
The PURPLE is the +5V part of the board that is either powered from, or powers, the WebControl board, TTL input pullups etc.
The GREEN is the common ground between all parts of the board.
The reason you're only getting 3.5 (probably 3.7 or 3.8V) from the opamp is that it's not a rail-to-rail device. It can go to ground fine, but it can't pull higher than about 1.2V from the + rail. At 5V - 1.2 = 3.8V, and is the primary reason I added the regulator, so we can power the opamp from +12V so the amplifiers can drive a full 0-10V to the analog inputs (without having to modify the WC board), while also providing 5V to the WC logic and not overheating the onboard regulator.
