todster said:I'd been debating using stubs into the outputs but was worried about stability. I'm not using the analog currently and probably not in the foreseeable future, although that could change. I'm more interested in the temps and humidity right now. I was mainly interested in powering the board from 1 source instead of having multiple. I was wondering about whether the 5v from your board would power up the W/C via the 24v.
My thought was to put terminals above the outputs and use loops up into the inputs for the 2987. I stumbled onto the 2987 and liked it because the inputs on my plc are sinking.
Now I'm going to have to look at something compact for a switching ps to 12v.
I already have a separate board right now with the ULN2003's but it requires pull ups and got unsightly rather fast. It also requires inverting the inputs on the plc. Not a big deal to NOT the inputs in the program. I usually put all the inputs into internal bits, so I could do the inversion then.
Part of the reason for the regulator on my V2 terminal boards was specifically to address the issue of multiple power supplies, and yes, it can run the WC board directly without needing to even connect anything to the two-way power screw connector beside the output terminals.
The regulator is happy with 24V input, but to bear in mind the power dissipation. With the modest heatsink I provided, and running 24V into the board I was measuring 130mA with no temperature sensors connected. After about 10 minutes with no added cooling airflow, the heatsink had stabilised at 91 deg C. Within safe operating parameters for the regulator, but far hotter than I would be comfortable leaving it run. The regulator was blowing 2.5 watts out as heat. It would need a larger heatsink, and/or forced air cooling.
Rather than stubs, use 90-degree male header pins. Spaced right, you'd run a strip of 10 of them straight into the output connector (and optionally a couple more for power) and do up all the screws. It'd be quite stable and solid.
There is a drop-in replacement for the 7805 which is a switching version. Ebay item 121026036348 claims 5.5v to 36V input and up to 95% efficiency.
