miamicanes
My frustration at the moment is off the scale. I know what I want to buy, but can't find it *anywhere*.
I ran a 3/4" and 1/2" conduit behind the kitchen cabinets (well, more like *through* them). The ends are poking out of the wall in the laundry room.
Inside the wall, above them, are 4 more cables poking out of a third hole.
All 3 are about 6" above the floor.
I'm trying to find a decent-looking surface-mount double-gang box. It needs to either have at least 3 knockouts on the back (at least one of which must be 3/4"), or be suitable for mounting over a metal 4x4 box inside the wall being held on with a Raco old-work retrofit adapter (think: mudring with drywall clamps).
Now, the fatal blow: it also has to have a 3/4" knockout on a side, because I have a 3/4" run of smurf tube running along the baseboard behind the washer & dryer (wall is concrete w/furring strips + polyurethane insulation, so conduit can't go inside).
I'm totally frustrated at the moment. Wiremold makes surface-mount box extenders, but none with 3/4" knockouts. Others make surface-mount boxes, but only with a single 3/4" knockout in back. I found one with open back, but only 1/2" knockouts on the side. I almost broke down & settled for a 4x4 handy box, then realized they didn't have blank double-gang faceplates for them.
Jesus. Every single thing at Lowe's & HD *almost* does it, then reveals one fatal flaw to keep it from working (mostly lack of/insufficient 3/4" KOs). It's almost like there's a grand conspiracy to force us to try and pull 8 cat5e cables through 1/2" conduit by making 3/4" conduit impossible to terminate into anything old-work or surface-mounted :-(
