My dad owns a four-plex.  He pays the heat in the building because it's a central boiler system and he's required by law to cover it if there's no way to accurately split it up.  Each apartment has a separate thermostat, and when heat is called for, the boiler switches on if it's not already, and a solenoid valve opens that pipes the hot water to the baseboard radiators in the apartment.  Pretty common design.
The problem is, renters have a thermostat. They turn the heat up to 80 degrees and then leave the windows open because it's too hot. Heating bills are $500+ a month. Obviously, the cheap option is to put a $20-30 lockbox around the thermostat and set it at 68F (required state minimum for landlord controlled heat).
But I was thinking, it would be nice to be able to sense occupancy of the apartment and turn the heat down, and also be able to monitor remotely. My first thoughts were Insteon or Zwave thermostats, and then one of the devices to link it to the network so it could be monitored or programmed remotely. Set up a motion sensor in the living room of each apartment, and if there's no motion for 2 hours, turn the heat down to 60F. Here's what I would want the system to do:
- Be able to manage remotely. (internet connection in building)
- Don't allow the renter to turn the heat above 70F, or if they do, it immediately turns it back down
- Turn the heat down to 60F automatically when there is no motion in the main room for 2 hours
- optionally turn it down to 50F if there is no motion for something like 24 hours
- If the outside temperature is greater than the indoor temperature, disallow heat
Looks like a VERA and some $42 Z-wave thermostats are going to be the way to go. Thoughts?
