1  WHENEVER THE TIME IS 15 MINUTES AFTER SUNSET
            THEN SET Kitchen, Sink [2 (A2)] TO 40% BRIGHT, FADE RATE = 0
            THEN TURN Outside, Front [1 (A1)] ON, FADE RATE = 0
            THEN TURN Garage, Outside [14 (A14)] ON, FADE RATE = 0
            THEN SET Living Room, F [6 (A6)] TO 45% BRIGHT, FADE RATE = 0
    2  WHENEVER THE TIME IS 11:00 PM
         AND THE DAY(S) OF THE WEEK IS/ARE SMTWT--
            THEN TURN Kitchen, Sink [2 (A2)] OFF, FADE RATE = 0
            THEN TURN Outside, Front [1 (A1)] OFF, FADE RATE = 0
            THEN TURN Garage, Outside [14 (A14)] OFF, FADE RATE = 0
            THEN TURN Living Room, F [6 (A6)] OFF, FADE RATE = 0
    3  WHENEVER THE TIME IS 1:00 AM
         AND THE DAY(S) OF THE WEEK IS/ARE S-----S
    4  WHENEVER THE TIME IS 6:00 AM
         AND THE DAY(S) OF THE WEEK IS/ARE -MTWTF-
            THEN SET Kitchen (Tstat 1) TO HEAT
            THEN SET Kitchen (Tstat 1) HEATING DESIRED TEMP TO 67 DEG. F. (19 DEG. C.)
            THEN TURN Output 100 ON FOR 2 MINS
            THEN SEND EMAIL MESSAGE 1 TO (Email 1)
    5  WHENEVER THE TIME IS 8:05 AM
            THEN SET Kitchen (Tstat 1) HEATING DESIRED TEMP TO 60 DEG. F. (16 DEG. C.)
            THEN TURN Output 101 ON FOR 2 MINS
            THEN SEND EMAIL MESSAGE 5 TO (Email 5)
    6  WHENEVER THE TIME IS 5:00 PM
            THEN SET Kitchen (Tstat 1) HEATING DESIRED TEMP TO 68 DEG. F. (20 DEG. C.)
            THEN TURN Output 102 ON FOR 2 MINS
            THEN SEND EMAIL MESSAGE 3 TO (Email 3)
    7  WHENEVER THE TIME IS 9:30 PM
    8  WHENEVER THE TIME IS 8:00 AM
    9  WHENEVER THE TIME IS 12:00 PM
    11  WHENEVER Output 100 STATE IS TURNED OFF
         AND Kitchen (Tstat 1) HEATING DESIRED TEMP IS ANY VALUE OTHER THAN 67 DEG. F. (19 DEG. C.)
            THEN SEND EMAIL MESSAGE 2 TO (Email 2)
    12  WHENEVER Output 101 STATE IS TURNED OFF
         AND Kitchen (Tstat 1) HEATING DESIRED TEMP IS ANY VALUE OTHER THAN 60 DEG. F. (16 DEG. C.)
            THEN SEND EMAIL MESSAGE 6 TO (Email 6)
    13  WHENEVER Output 102 STATE IS TURNED OFF
         AND Kitchen (Tstat 1) HEATING DESIRED TEMP IS ANY VALUE OTHER THAN 68 DEG. F. (20 DEG. C.)
            THEN SEND EMAIL MESSAGE 4 TO (Email 4)
