I would follow IVB's lead and consider a simple light timer, since they are cheap.
You could hack the thing and disconnect the internal contacts from the 110VAC and use the contacts for your own use.
Or, you could get a wall wart and matching relay (probably 12 VDC), then use the relay contacts. this avoid all the high voltage hacking.
