I have a dead OmniPro II. The AC led comes on but that's it. I checked all the 12 volt locations on the barrier strip and they are 0 volts.
No heartbeat led. I don't think the rest of the board is damaged. Nothing obvious. I took the eprom out and read it and its good. No smoke smell.
Is there an on-board fuse other than the resettable one for the outputs?
I suppose I need to start with the bridge rectifier and see if it has any output.
Found it... Just put pressure on the two raised resistors on the power section and it woke up. Will re-solder them.
