Im not permitted to upload my export.
But I got some switches programmed. But I have a flashing issue. Every 2 seconds they flicker. The LED is blinking magenta aswell. Though its programmed to blue when off, off when on.
CFL/LED switches, though most lights are still incandecents, though specs say they can handle 600W incandecent load. I plan to slowly switch over to LED. I do have some installed in the house (sylvania 12W A19)
Also outside are 9W PAR20
Any ideas, or can someone explain why i cant upload export?
*edit* went and disconnected PIM from OPII and unplugged. Still blinks
Reset programming in panty. Stops blinking.
*edit 2*
I read install again. Says blinking magenta is timer, so I double checked my upstart, timer is not ticked. All lights do it, unless I send an on command from the test tab in upstart. Manual puts them full bright, with blinks
