Can the program file from an updated OMNI IIe load into an OMNI Pro ? I have all 500 lines of code used on the OMNI IIe and don't want to start over with a "blank sheet". Can get used OMNI-Pros on ebay.
Your answer "implies" that the OMNI IIe configuration file is compatible with OMNI Pro. So I don't make a mistake of buying something I won't use, can you confirm compatibility ? Should I be looking for an OMNI Pro II , rather than just an OMNI Pro ?
