USB Temperature sensor - Is there any?
KenM
Hi,
I am searching for a simple, inexpensive, temperature sensor that I can connect into a USB port (or WiFi). I am currently using Z-Wave and some minor INSTEON stuff.
My goal is to be able to have this sensor report a temperature to a HA system like HomeSeer, so that I can activate basic cooling or heating HA via a web interface. I trashed my old TempLinc months ago. It got too un-reliable. Too much noise I guess.
I write a lot of my own software so that is not a problem, a plug in solution would be great. If prodded enough, I could create a HS plugin for something like this.
I received today, a 'Go!temp' (from Vernier) USB sensor. I can make this work, as they offer up the SDK for free.
If any one knows of some type of temperature sensing software/hardware for a person on a budget; please chime in.
Ken
edit added:
The Go!Temp sensor looks like something a evil nurse might use, it is about seven inches long. I am hoping for a miniature sensor.
k
ctwilliams
It may be overkill, but you could use a Labjack and make your own temperature sensor that could be pretty small.
I think Homeseer has a plug in for Labjack....
CT
pete
Have you looked into One-Wire stuff from Dallas Semi
they have a USB adapter, cheap temp sensors and good development resourses . .
Pete C
PS. they are very accomodating to request for samples :(
KenM
Thanks all,
I had considered the Dallas '1-wire' devices but I was not sure if they had any support. The '1-wire' devices are new to me. Are any USB interfaces supported? If so, by who?
I would enjoy obtaining a SDK for these things. :( Anyone know how that might happen?
Regards,
Ken
ericvic
KenM said:
Thanks all,
I would enjoy obtaining a SDK for these things. :D Anyone know how that might happen?
Regards,
Ken
Ken,
Dallas has an SDK for their 1-Wire masters.
Eric
applecake
Hi,
Ken
edit added:
k
LM335 temperature sensors plugged in to an analog input module.
A top16 analog input module from tctec will give you up to 7 temperature inputs, and one input for a reference voltage (LM336)
BraveSirRobbin
Moderator
Are you getting adequate resolution with these temp sensors? At 10 millivolts per degrees Kelvin I wouldn't think you would get enough output for a typical resolution range needed for a home (say -30 to 110 degrees F).
KenM
Just as a FYI to all,
I ended up with (several) HomeSeer's HSM100s (Z-Wave). No wires, good and bad. The battery will eventually fail after about six to ten months. The 'good' part is that, on a weak battery, the temperature and light level readings seem to keep working while the motion part reports a continuous motion event.
Any more, I just replace the battery every five months. These things came to market after my original post.
enjoy HA!
ken
applecake
-30 F = 238K = 2.38 Volts
110 F = 316K = 3.16 Volts
The input is 0 to 5 volts, 12 bit.
workable precision is better than 0.5 degree F, uncalibrated accuracy depends on LM335 sensor model, but +- 1 degree is normal.
