Using TTS with Voice Modems
upstatemike
What is the best way to speak TTS messages or play wav files through a voice modem? I want to dial a number, usually 33* for paging access but maybe sometimes an outside number, and then have a TTS message spoken over the phone.
Is there a simple way to do this say inside a batch file for example? Also do I need a particualar modem or will any voice modem work? Is there a cheap USB connected voice modem that people prefer for this application?
jeffx
Mike,
I am not quite sure what you are trying to do here. Could you give a specific example?
Do you want something similar to HAL2000, where you can do the VR and TTS/Audio through a phone line?
i.e. with HAL2000, I pick up any phone in the house, press "*" and then speak a VR command or punch in a 3 digit code to perform automation tasks. Any audio responses are also then transmitted over the phone.
Edit: My incoming phone line goes through the following path:
Incoming line
Alarm Panel
Alarm Panel Alpha Pager
HAL2000 V.92 Voice Portal Modem
then parallel to the Intercom system and house phones
upstatemike
jeffx said:
Mike,
Example:
When I get mail in the mailbox my Stargate picks up an extension on my Panasonic phone system, dials 33*, and speaks a message that the mail has arrived.
I would like to offload that to a PC as part of an overall reorganization of my paging system. The Stargate will kick off a batch file to trigger the PC announcement so it remains free to do another voice related task.
I'm just trying to figure out what I need to get the PC to do this.
