I finally had the incentives to mount my VisionTech 0 lux camera (Halloween), so I decided to try Martin's advice, and run some cat5, then run power from my server room to the camera over 1 pair, and the video signal over anoher pair. The length of the cable is 127ft, and the picture is perfect! I measured the voltage, it's 12.49VDC at both ends, so that won't be a problem either. I am not using any baluns for the video signal, just 2 RCA connectors. I know some had doubts that this could be done without any baluns, which is why I posted here
I attached a snapshot, it's a little bright as the sun is hitting the lens, and I don't have the shade installed, but it still doesn't look bad at all. The camera works pretty well at night too, the only problem I am having are the IR led's, which have a red glow, attracting bugs, setting off the motion detection in my webcam software, as they come really close to the camera. I might do a full review on this camera later, pics of wiring can be posted if desired, I just have to take some when I get home.
