Keep in mind also that there is a 1,000 watt dimmer you should use if 600W is too small. As Chris said, this is for incandescent loads. If you have an electronic low voltage transformer as your load, or a magnetic transformer, be sure to get the proper dimmer.
Watch out for the 15 amp switches. They REQUIRE that a neutral be present, but many homes are have switches wired such that there is no neutral (the switch just interupts the HOT). In this case, you'll have to use a dimmer instead.
