Actually, if you want to have accurate reading every time, the Rg should be a metal resistor, not pot. Pot is too easy to change its value.
Your load cell rated outout is 1.0946mv/V. That means if you use the 10V ref from that chip, wiring like Fig1 in page 10 of that TI datasheet, you will get max 10.946mV output with 5KG load. -- because that Fig 1 using 10V ref voltage. On page 11 of the INA125 datasheet, it stated that "Positive supply voltage must be 1.25V above the desired reference voltage." That means if you want to get 10V ref, your support voltage must be 11.25V and above.
Higher supply voltage will allow your load cell having higher output. If you power INA125 with 5V, The max Vref is 2.5V from that chip. Then your load cell output max will be 2.5V x 1.0946mV/V = 2.7365V. Your INA125 max output is 3.8V when its power supply is 5V. If you power the chip with 10V, you will get max output 7.6V. I think you want to use as high supply voltage as possible. For example, use 9V (or 12V whatever you are using) power that supplying the WebControl board.
Your max output voltage divided by the max load cell output, that is the gain you need to set. Say you use 9V power supply, and you will probably get about 6V or so max output from INA125. When using 9V, your Vref will be set to 5V, your load cell max output will be 5x 1.0946mv = 5.473mV. Then 6 / 0.005473 will be the gain you need to set. That is something like 1096. From the chart on the Fig 1, that Rg is less than 60 Ohm. On that same Fig 1 of the datasheet, you see there is a fomular:
G = 4 + 60K / Rg; from that, Rg = 60k/(G-4) = 60k / (1096 -4) = 54.95 Ohm.
Try to find a fixed value good quality metal film or wire resistor, that will help your setup accurate over the time.
Then, after all this working, you can put a known weight and read from WebControl analog input to see what is your known weight reading. It is better to have some kind of calibrate weight to find out their reading. Supposedly they are linear. With two known weights, you can figure out what is the curve looks like, then do a calculation in PLC code to determine the display value on VAR.
