The Pod
I'd like to automate the closet lights in the house so that when someone opens the closet, the light will go on for only 10 min. or off when door is closed. Simple enough to hook up a magnetic sensor on the door to an Elk input zone. But the question comes up of which is a better way to control turning the light on and off? What types of pros/cons do I have between these two setups:
a) Wire the 110 power for the closet light to an Elk relay board and connect it to an Elk output.
Install an Elk Serial Expander with controller (Z-Wave,UPB, etc.) and connect a module at the closet light.
Also open to suggestions of other ways to control it with the Elk.
The Pod
The Pod
