Hello,
I'm building new and have some Anderson Silverline single hung windows. I can't figure out a good place to hide the contacts on these because there is a metal "sleeve" between the sash and the frame that the tension wire runs inside of. This sleeve is preventing me from putting a rare earth magnet on the side of the sash and contact in the frame because the sleeve would be in between them. I do not want to put the sensor in the bottom of the frame (to avoid water leakage). Is my only option to use a surface mounted contact like the Tane pill? Pics below. Thanks for any suggestions.
