Sorry if this question has been asked before...
Not clear to me what kind of Cat6 cable to specify for a new home construction. Will run miles of this stuff for everything from a 1Gig network to IR blasters to Nuvo audio control panels to even some line level audio (this one might be a bit chancy). For future proofing I'm not even going to bother with Cat5.
There are a lot of types to pick from. Don't think I need the plenum rated stuff (CMP) as none will be routed in ducting. The wiring from the server room will be in conduit to the attic where it distributes out. But once its in the attic from there it might get non-conduited to each end point (riser?). Not sure how that part will play out.
Questions:
1) Stranded vs. solid?
2) CM, CMR, and CMG? Which is necessary?
3) I've read about possibly not wanting to mix and match cable brands with other manufacturers connectors. True?
4) Can you use Cat 5e connectors with Cat 6 wire?
5) What about crimp tools? I have a CAT5 crimp tool that I once tried to use on CAT6 cable with horrible results. I never could get all 8 wires to connect.
Thanks.
P.S planning on getting as much as possible from monprice.com.
Here's a trade view, as I deal with this on a daily basis with enterprise grade networks and security, specifically in a bunch of world renowned healthcare facilities as well as research facilities....not bragging, but it's the fact.
1. All horizontal and backbone cabling needs to be solid. Stranded is only used as a whip or short patch from permanent wiring.
2. CMG or CMR are both acceptable in a residence. You do not need a riser cable in a residence...I forget what the "story" rating is, I want to say 3 offhand, but I'd need to look up the reference, as we typically use riser cable. Plenum cabling is not intended on running within ductwork, many people misinterpret what a plenum is and when plenum cabling is required. Normal cabling can't be run through supply ductwork or similar without paying attention to special wiring methods. Plenum cabling is only required when the airspace, typically a drop ceiling, is used for return (or enviromental make-up) air, not a supply.
3.Cable and connector mismatching is a myth. As long as a quality manufacturer's components are used, I've yet to see a foul.
4.The facts with various connectors and cabling is this, contrary to most people's ideas: Most popular category connectors will work with any category cable, as the typical cables only range between 22 and 26 AWG, which isn't that great a dimentional range when working with IDC connectors. Cat 5 ends will work on Cat 6 cables and vice versa, it's only a matter of the skill of the person making the ends and the tooling/connectors being used. The problem lies, however, when Cat 6 cabling is terminated using Cat 5 hardware, as the rating of the installation will only test at the Cat 5 spec, no matter how well the field cabiling was done and integrity at the ends were maintained.
5. The understanding of a ratcheting crimp tool is off here....they're only used to verify a full "crimp cycle" is completed, not the integrity of the crimp, as the dies are typically the limiting factor, in addition to the jack itself. Open barrel pins and sockets, yes, a ratchet crimper does make a difference, but only to adjust the amount of crimp and prevent overcrimping the pin/socket on the cable. Actually, I've experienced worse performance with a lot of ratchet crimpers based on the design of the die, crimping side to side instead of straight up/down. The easiest manufacturer to locate a quality crimper would be Ideal. We use GMP, as they're the only crimpers accepted by ATT and Quest, among others, for the crimp integrity, however I doubt most would spend upwards of $2-300 for a modular plug presser, with used going for 1/3 that price typically. I've had exceptionally poor results with Paladin as far as ratchet crimpers and the quality of the crimp (as mentioned above for an example).
The truth is Cat 6 has improved speeds over C5 and C5E, however most typical networks don't see a difference between C5E and C6 unless they're doing heavy imaging (such as medical equipment) compared to typical file transfer. Most IT folk specify C6, when even their switches, routers, and even computer NIC's can't even support the spec, because they have a number or idea that it is "better".
The best advise I would offer someone regarding a network, especially wanting to future proof, would be to spend the money up front for a composite cable that contains fiber. Use the UTP cables in it now and then migrate to fiber if the UTP is outgrown. The real way to plan your network and install would be to approach it as an enterprise network and if you're going to be running multiple applications and hardware on the network, separate the network into VLAN's and assign them to their own VLAN rather than slam everything on the same network, you'll get better results.
