Update status - Help
Original installation picture - most difficult installation in house was master bedroom. Here I removed the metal mudplate and replaced it with a plastic one and used Wago nuts instead of the twist nuts. 3 light load wires in the box (1 - wall outlets 2 - Fan light 3 - Fan)
12th May 2023
Here have had no issues with my 3-4 Treatlife==> Tasmota Fan Light switches since installation in 2020. Mostly it was fitting these switches in the dual gang metal boxes with UPB switches that caused me grief. These switches were installed in 3-4 rooms with unique circuits. I removed the fan light in the kitchen here.
That said I did convert two more of these switches for a peer in TX. These are in the same gang box and control two fan / lights (LED).
Problems in TX relating to this post on Amazon.
I've been looking for a cost-effective smart fan/light switch for a while and the Treatlife Fan/Dimmer switch appeared to tick all the boxes. I initially installed 3 of these on ceiling fans in our house, but I soon discovered some very odd behaviour under certain circumstances.
Most of my other switches in my house are already smart wifi switches. Some are straight on/off switches, others are dimmers. All require a neutral for proper functionality. I've noticed that when the Treatlife fan/dimmer switch is installed on a circuit that already has a smart dimmer switch, turning on the other dimmer switch would ALSO turn on the fan light. As you turn up the brightness on the other dimmer, the fan light brightness would turn down. My 9-year old thought his fan was possessed by ghosts when his bedroom fan light turned on in the middle of the night when we turned on the hall lights (on a smart dimmer) at various points in the night.
After much troubleshooting (and frying one of the 3 Treatlife switches) and online research, I found the problem. Old dimmers used to make incandescent lights dim by adding resistance at the switch, which would make the switch warm. That approach doesn't work with LED lights, so they now essentially dump unused voltage to the neutral wire. When you turn the brightness down, more voltage is dumped to neutral. The Treatlife switch is passing this voltage through to the light, which explains why turning up the brightness on one light would turn down the brightness on the Treatlife. This doesn't happen with any other dimmer, including the smart dimmers that were on these same circuits.
As such, I cannot recommend this switch if you have any other modern dimmer using the neutral wire on the same circuit.
I actually contacted Treatlife about this. They admitted that they don't support multiple smart dimmers on the same circuit because of this issue. For anybody else considering purchasing this dimmer (or any other Treatlife dimmer), make sure there won't be any other smart dimmers on the same circuit or you'll run into trouble.
TX Peer had an electrician run separate light / fan control wires down to the wall gang box. Dual gang box with two fan light switches both with same hot and neutral wire. (he calls them north and south fans).
Here purchased Jasco resistors for my UPB switches (connected to my LED lamps). I get no flicker when dimming my LED lamps in the house. I suggested the resistor fix for the light loads on the two fan light switches.
Odd for the peer in TX that the Jasco resistor worked on one combo light fan switch but not on the other one. Peer thinks it is a hardware problem with the switch. So today he is switching them to see. Personally I think it is a wiring issue and suggested adding the resistor to the light box under the fan.
Peer has tested with a volt meter and sees 1-2 volts on the neutral (white) wire when checking against copper wire in romex when the switch is off.
Any suggestions for further testing. I have also suggested doubling the resistor on the willy nilly switch or putting it in the light box.
