Hi all.
(sorry for my english, it's not my mother language)
I buyed multiple switch of GOSUND :
- 6 Gosund Dimmer DS1 (ref SW2-WIFI-V4.0)
- 2 Gosund 3 way SW6 (not yet opened)
- 4 Gosund switch DS1 (ref SW5-WIFI-V1.0)
I want to flash the switches with Tasmota (to used with Domoticz after).
I am computer scientist, not electrician but i use raspberry, play with arduino, and volunter to learn.
I need some help to flash the SW2-WIFI-V4.0 with raspberry pi, arduino or key CH340G ... but all of my test fail....
I do 2 tests : I have soldered wire on the board with 2 switches :
- Black : ground
- Red : 3.3V
- Yellow : TX
- Orange : RX
+ Green on GP00 (second test)
First test : tuya-convert
Multiple test, impossible to flash, the switch reboots every time.
Ok, i read the documentation, my firmware is to new, it needs a key from China to flash to ESP ...
Second Test : Raspberry Pi
On raspberry, i fallow this tuto : https://tasmota.github.io/docs/Flash-Sonoff-using-Raspberry-Pi/ respecting the wire schema
No result, impossible to send data or erase the ESP.
ESP01: Failed to connect to Espressif device: Timed out waiting for packet header
I switch TX and RX, same result.
Connexion to GP00 to the ground, same error.
Click on button to have green flashing light, same error ...
Thirth test : Arduino
I connect the Arduino to ESB, using same wires.
Ground to ground, 3.3V to 3.3V, TX to RX, RX to TX, and GP00 to Ground
Using ESPTOOLS, same error ...
4th test : CH340G
I buy on amazon a CH340G (recommanded by Tasmota)
I connect the 3.3V to 3.3V, ground to ground, grount to GP00 9using breadboard), TX to RX and RX to TX.
I use Tasmotizer to send data/erase or flash the ESP, same error, impossible to connect
At this moment, i don't understand what is my mistake...
I try with 2 differents switches and every test fail ...
Have you an idea for me ? I need help
I can post also photo of connexion if you want.
Thanks very much
- Black : ground
- Red : 3.3V
- Yellow : TX
- Orange : RX
4th test : CH340G
Thanks very much
